Does anyone have any experience with air bag jacks? It could be a handy solution to jack up an Emira easily.
So this Vevor air bag jack in its deflated position is about an eighth of an inch to a quarter of an inch too tall to fit under the Emira jack pad. I think the three-quarter of an inch rubber pad that comes on the airbag jack could be replaced for a shorter rubber pad so it would work.Does anyone have any experience with air bag jacks? It could be a handy solution to jack up an Emira easily.
"If you can't raise the bridge, lower the river".So this Vevor air bag jack in its deflated position is about an eighth of an inch to a quarter of an inch too tall to fit under the Emira jack pad. I think the three-quarter of an inch rubber pad that comes on the airbag jack could be replaced for a shorter rubber pad so it would work.
View attachment 49921View attachment 49922
I went ahead and purchased some Race Ramps Scale Ramps. I figured they would be handy for jacking low ground clearance vehicles and make it easier to drive up on my scales."If you can't raise the bridge, lower the river".
Just drive the Emira up on to 1 or 2 inch tall storage blocks like these or similar. Or make your own. Should work, right?
Where did you get these schwaben? Can’t seem to find them.By the way, this is the lower QJ setting, with about 11 inches from underfloor to ground. Full height is about 24 inches of access.
My "safety blocks" shown:
Sold by ECS Tuning:Where did you get these schwaben? Can’t seem to find them.
are you buying ONLY for Emira use, or for other cars as well?I have just read through this whole thread…. What is the consensus for the best fitting Quickjack in regards to the Emira. Buy the 5000TL or the 5000TLX? Or is there another brand that seems to fit even better for the Emira?
Mostly for Emira…. But would like to use with Maserati Levante and a AMG C43. All under the 5000lb limit.are you buying ONLY for Emira use, or for other cars as well?
Sorry @DigDugLotus , I thought I replied to this before.Mostly for Emira…. But would like to use with Maserati Levante and a AMG C43. All under the 5000lb limit.
Yeah, thanks for the response. I did go with the QuickJack 5000TLX. Did the Maserati and the Mercedes easily with it. Just waiting on the Emira to arrive…..Sorry @DigDugLotus , I thought I replied to this before.
Check out https://quickjack.com/support/measuring-guide/
You can measure the points where you want to lift the Maserati/AMG/Emira and see if there's one particular size that fits all three without being too long and interfering with tires.
Cheers!Yeah, thanks for the response. I did go with the QuickJack 5000TLX. Did the Maserati and the Mercedes easily with it. Just waiting on the Emira to arrive…..
