I am curious about this and will report back. If you go through all of the exhaust posts, it seems that it was a few early cars that had this issue. However, later designs on several different exhausts and perhaps a loosening of the calibration from Lotus have contributed to not hearing about this anymore. I'll certainly post here as soon as it's installed, with pics and if I had any dash warnings.You’ll probably need to get the exhaust valve re calibrated at Lotus if you change the exhaust. The valve is super sensitive to the slightest difference in the open and closed position. I had CEL after changing my I4 Exhaust, after recal, no problem.
