GRP Short Shifter Install Notes and My thoughts
I would just make a mental note of how many turns it takes from initial engagement to fully inserted and maybe not back off more than 40% of the turns so that there is plenty of thread remaining engaged.
Thanks for the advice. Knowing how much thread is left should lighten mental stress contributing to the shifter stalk ED 😆
You are asking for trouble. The stud that the GRP eyelet mounts to is fixed in place by the same nut that holds down the eyelet. So if you remove the eyelet, that stud may fall out?
I did consider that, but think the stud will be trapped in place if the nut is removed after the unit is pushed on to the bell crank. However, since it is cold ;) the chances of nut fumbling and nut loss increase. I dunno, guess it will depend on the weather and how I'm feeling that day. I'll figure it out. As you have pointed out, the important thing is to make sure your stalk stands proud before reinstalling the cotter pin.
As mentioned above, I do the same and adjust it visually by looking through the rear window at the shifter and then verify by sitting in the car and giving it a little test before locking everything down.
Having the shifter in the 100% exact position isn't critical but you want it as close as possible.
  • #23
Man.. Wish I knew all this before doing the install. I messaged Greg on FB, but didn't hear back and didn't think to message him here.. Prob should have.
I think my friend is fine with where it is for now.. He hasn't complained yet.. so I won't be bringing it up, but if I do my own then I am def going to be looking through the window to check where the shifter is and adjust that way.
Thanks for all the info guys.
Ryan G
Ryan G
I dont use FB messenger for business, sorry. Email is the way.
Thanks to @RyanGphoto for starting this informative thread. I have learned a lot. Other than dropping the OEM eyelet into the abyss (will have it retrieved next visit to the dealer for an oil change), the install went smoothly. Attached is my contribution to those who are worried about "messing up the neutral position". Worked perfectly for me.
I can fabricate these for $500USD each + shipping for those interested. Yeah, the cost may seem steep, but there's a lot of manual work involved in the manufacturing process...
