- Joined
- Dec 21, 2021
- Messages
- 1,291
- Reaction score
- 2,329
- Location
- Tokyo, Japan
- Emira Status
- Emira Owner
Thanks for the advice. Knowing how much thread is left should lighten mental stress contributing to the shifter stalk EDI would just make a mental note of how many turns it takes from initial engagement to fully inserted and maybe not back off more than 40% of the turns so that there is plenty of thread remaining engaged.
I did consider that, but think the stud will be trapped in place if the nut is removed after the unit is pushed on to the bell crank. However, since it is cold the chances of nut fumbling and nut loss increase. I dunno, guess it will depend on the weather and how I'm feeling that day. I'll figure it out. As you have pointed out, the important thing is to make sure your stalk stands proud before reinstalling the cotter pin.You are asking for trouble. The stud that the GRP eyelet mounts to is fixed in place by the same nut that holds down the eyelet. So if you remove the eyelet, that stud may fall out?
