Japan - Emira Ownership (エミーラ納車とその後)
Why that happned? No idea?
Most likely a software bug. It happened shortly after reaching the 1,000km milestone.
そもそもが TPM センサーの技適対応までの一時的なソフトウェアのパッチなので謎のバグが埋め込まれている可能性はありますね。
Just got a Low Tire Pressure warning on a system without TPM !
こりゃびっくり!w
Locked the doors, put the keys in a shielded box, and the Tire Pressure warning disappeared the next morning.
施錠後に車とキーの通信を遮断し、一晩おいたら直ってました。忘れっぽいんだな、きっと。
Nope. Started the car and the warning is back. Seems like a persistent warning and needs to be cleared. I have an ODBC dongle, but decided to leave it as is so the dealer can see it when I bring the car in next month.
バッテリーの充電レベルが低くなると発生することもあるそうなこの警告、やっぱり消えなかった。
Does anyone know if it's legal to install aftermarket seats in Japan? Legal as in passing shaken and not voiding manufacture's warranty. I just had a kinda-spirited run around the mountains and I gotta say the seats are absolute crap in holding you in place.
I tried using an aftermarket Android Auto USB to Bluetooth adaptor, and IT WORKS. The unit I bought is the "A2AIR Pro" from "ottocast". Although there are similar products for half the price, I chose this one because it has FCC and Japan "Giteki" certification. They make an iOS version called "U2Air Pro" for those of you with iPhones. Both are available on Amazon, Rakuten and other major online stores.
Android Auto を使うためにスマホを有線接続するのが嫌で気になる商品をポチってみたところ、ちゃんと使えました。半値ぐらいのものが多数あるようですが、Ottocast 社の "A2AIR Pro" は技適取得済と書いてあったのでコレにしました。アマゾンや楽天などでは1万円ちょっとで売られています。また、Apple Carplay 用の "U2AIR Pro" も販売されています。商品名が紛らわしいので要注意です。
The kit contains the module, USB cables (for Type-A and Type-C), double sided tape, and a user manual. I selected the Type-A cable, thinking that the ports and connectors are mechanically stronger than Type-C. The double sided tape is extra strong; use with caution. I stuck the module on the underside of the center console lid. No issues with reception from the cup holders and phone tray.
箱には本体、USB ケーブル2種類、両面テープ、説明書が含まれています。両面テープは強力なので位置決めは一発で決めないといけません。ひじ掛けの蓋の裏側に設置して使っています。
I have absolutely no idea why, but connection was intermittent during the first hour or so of usage but then started to work flawlessly after that. Maybe the module was "learning" something? Not that it matters to me anymore.
理由は全く分かりませんが、初めのうちはブチブチ切れていた接続は小一時間で安定するようになりました。その間にしたことと言えば、給油をしたのと車を施錠してトイレに行っことぐらいでしょうか。とりあえず、ケーブルから解放されて快適です!
ottocast ==> https://ottocast.jp/
Best mod so far... no more dash reflections in your face...
Waiting patiently for some vendor to produce this with openings for air, speakers, and the flashing red LED...
専用設計のもの熱望...
I would suggest asking your dealer about the warranty. Shaken for a two seater should not be too hard.
Why don't you consult with us here?
【参考】英語のスレッド Aerie Performance Emira V6 carbon fiber engine surround group buy でV6用のカーボン製エンジンルームカバーの団体割引第二弾の募集が出ています。今回はだいたい20%引きのようです。
Twill weave carbon fiber and forged carbon fiber with gloss or matte finishing:
- Retail price: $1090
- 2nd group buy price: $880
Herringbone patterns carbon fiber (V weave) with gloss or matte finishing:
- Retail price: $1190
- 2nd group buy price: $980
スレッド上で購入希望の意思と仕様 (次の2項目) を書き込み、Aerie 社からのダイレクト・メッセージの指示に従って購入手続きをします。最初は定価の画面が出てきますが、チェックアウトまで進むと割引が表示されるので確認してください。
  • 編み: "Twill" / "Forged" / "Herringbone" から1種類を選択
  • 仕上: "Gloss" / "Matte" から1種類を選択
ちなみに、私は団体割引第一弾で "Herringbone / Matte" を選択しました。リヤハッチへの写り込みを嫌って艶消しを選びました。
こちらのベンダーさんも V6 用を出してきましたね。前出のベンダーさんよりも少し価格を押さえてます。
これはダメだ。触った瞬間にズレるので意味がない... かわいいけど。
Cute, but totally useless against the cold. I do not recommend this mod.
I got myself this one 😂
Agreed doesn’t help with the cold at all, it does help a lot with the heat tho!
Anybody else have these brown spots on the exhaust tips? I tried car shampoos and mild detergents, but it won't come off.
このような茶色っぽいシミありませんか?取れました?
If it is painted, then I would start with a cleaner wax. If that doesn’t work, then try polish.
Thanks! I'll try that when the car comes back from the first (1,000 mile) maintenance.
Ouch. PPF repair was costly, but looks like new now.
自宅車庫内のバイクに擦って捲れ上がった PPF の貼り替え、けっこう高くつきました...
First service complete:
PPF 施工業者さんの予約がなかなか取れず、だいぶ遅れての一カ月点検:
  • ECU update (hope it doesn't break anything)
  • oil and filter changed (7 liters of 5W-40)
  • visually inspected, then tested the hypersensitive front left parking sensor and wiggled the connectors and harness (from the short drive home, seems to have fixed the hypersensitivity - yay!)
  • a bit of beveling on the brake pads
  • adjusted front fender and bumper alignment as much as possible
  • TPMS error reset (still no date on TPMS functionality availability)
  • exhaust tip discoloration reported to Lotus (let's see what the response is)
A Shadow Grey auto and Seneca Blue manual were in the showroom today. Red interior looks classy!
  • seems like maybe two thirds of the Japan V6 cars have been delivered to customers
  • progress is slow with the PDI center being the bottleneck, which means there are still many cars sitting at Daikoku
  • no news of i4 cars yet.
I noticed the same thing on the dealer demo car I test drove a year ago, I suspect this will become common over time and usage. Looks very much like corrosion spots to me ☹️
