Featured
- #41
Best results when driving my Grand Turismo EvijaWow!
How much HP and 0-60 you get from that?
Does it have cupholders and hydraulic steering?
I wired some Rockford Fosgate tweeters into the headrests of my Mazda MX-5 (Miata)... the cutouts were already there (oddly). It was a weird thing, hearing directional sound behind your head while driving...
It's a type of free-air subwoofer. Those have been around for many decades, but rarely integrated into a car because in car companies the audio system is typically designed in a very late step after the completed engineering of the unibody. Integration of the subwoofer venting into the car body is a very recent development, and a good one. My BMW actually has under-seat 8" bass units in the floor that are each in their own box that vents into the adjacent frame rail of the unibody and uses the air space there (which opens to atmosphere at multiple points) to propagate/dispel the back-wave.- I haven't heard it yet, but am I understanding right that the sub is basically installed on the body? If that's correct, then how does the sound change when the windows are down? Curious why they would leave a variable - use a box for consistent results?
Someone last week stated that there was a power upgrade to the system they were going to be doing for production cars. Maybe that is it? I hope so, because 340 is kind of low-end for the "high-end" system it supposedly is getting.Sorry to bring up an old thread, but the references here are for 340 watts for the KEF system. On the configurator (US), it now says "560 w". Is this a change to specifications?
Somehow there still exists optimism on this forum.It's crazy but I just had the feeling that Lotus is maybe using their pre-production cars and comments from journalists all over the world to really improve on the things that really have to be sorted out still.
And finally, maybe in spring 23 we will all be surprised as all the issues before have been adressed and are sorted out then. Wouldn't that be a nice surprise?
I think they are really hanging behind their targeted time-schedule in a lot of areas, but they were forced to release earlier than they would have wanted to. But sometimes also pressure is useful to get somewhere. Only under highest pressure a diamant will come out...![]()
I'd love to believe that, but I think it's pretty clear it's just a wait for parts nowIt's crazy but I just had the feeling that Lotus is maybe using their pre-production cars and comments from journalists all over the world to really improve on the things that really have to be sorted out still.
The power amp is a line level Harman booster amp so it’s an easy swap. Will be a piece of cake to swap it aftermarket as there’s no fibre connection using MOST or A2B protocols by the looks of things.Parts shortage could explain the power boost. They may have been forced to switch to more powerful chips due to availability. A lot of the class-D amplifier chips are pin-compatible and can be swapped without without too much redesign (well... you need higher supply voltage, thermal management, and output filter component size, but that's all a piece of cake in the modern day).
Of course, this is just conjecture.
I hope you’re right. That would be the smart thing to do. Never waste an opportunity.I have suspicion that while they are awaiting parts, and hence need to delay production, they may well be taking onboard comments from journos and others to make some improvement tweaks where possible
You took the words right out of my mouth...lolI wonder if they will change the V6 to a V8![]()
I heard a rumour that they were tweaking the chassis setup. I believe recently there was information released suggesting that there is now going to be slightly different ride heights between sports and tour.I hope you’re right. That would be the smart thing to do. Never waste an opportunity.
