Great effort for a great matching result. Your directions may help others wanting to change their letter color but I suspect your Emira may be fairly unique since few others will be up to the challenge of doing all that meticulous work. Congrats!
Went for a 300miles drive, far too much traffic to enjoy it properly
Tried sport mode for the first time, damn its addictive
Test fit battery charger for the winter, 6 foot extension cable, lets you keep the charger off the car. Seems to work well when on the top of the lift.
Thank you. It does require an extra effort to get it done right. I hope the information I’ve provided proves useful for those who do attempt their own badge mod.
Tow hook... bought the same from GRP, fully screwed in it stays at about 45 degrees to the ground level 😖
You might try putting some thread sealing tape on it to help get a better alignment. I tightened mine by hand and then used a wood dowel to barely finish the last bit to level. I didn't want to go too far and then have to loosen it to get level. It has been rock solid since. The threads have a little Delrin pin through them that helps add resistance so that you can get it level without bottoming out the threads.
Washer of various thicknesses will help align it if you’re ocd about it won’t it?
Bags packed ready for the start of our re 3000km road trip over the next two weeks.
Leaving Adelaide tomorrow morning for Melbourne (Geelong) to catch the ferry to Tasmania where some of the best roads and scenery in Australia await.
Will be a great test of the car.
Genuinely surprised at how much we can get in these wonderful Bagworld bags.
  • IMG_6839.mov
    18.2 MB
I wouldn’t feel comfortable DIYing this with Chinese parts. Seatbelts are an important safety item. That’s just me though. They look awesome and aliexpress is crazy cheap. Normally it’s like $100 or so right?
I went to a local auto repair shop and they wouldn’t replace seatbelts unless using all OEM parts, making it impossible to change seatbelt color.
The AliExpress belts look to be all 3.8 metres long by 4.8 cm wide (per seat) and some specify 1 cm thick with child seat webbing being thicker, whereas other listings don’t mention thickness, like the listing for the webbing GlobalPilot777 purchased. Like kitkat I’m curious to know if GlobalPilot777 replaced the webbing himself or found a shop willing to do it.
Some AliExpress listings mention the need to sew the supplied buckle fasten buttons and recommend a professional do that, plus some mention sending them the old seatbelt assembly and they’ll substitute the webbing with normally a 2-day turn-around time (no costing mentioned), so perhaps GlobalPilot777 sent his to them?
Hopefully GobslPilot777 will provide more details.
I’m interested in installing a striped webbing AliExpress has listed, but those listings don’t describe the webbing strength, so I suppose it’s somewhat “iffy” safety-wise and I’d have to trust AliExpress, which “seriously” isn’t keen to do. Decisions decisions…
@netsinah check these posts out. I had good experience with this company:
Post in thread 'Everyone's Mod Priority List'
https://www.emiraforum.com/threads/everyones-mod-priority-list.4127/post-120680
https://www.emiraforum.com/threads/everyones-mod-priority-list.4127/post-120677
