denk0815
Of course they are not.This is very confusing. I'm actually not sure how this "Cambridge Car Audio" company is even allowed to call themselves that, considering there is a very long-established audio manufacturer in the UK called Cambridge Audio.
Hey,As promised, here are the final 3D printed versions of the front and rear speaker mounts, & Amp Mount, allowing you to upgrade your KEF audio to a far superior system. The front mounts allow you to transform from a 3" speaker to any 6.5" speaker, and the rear mounts allow you to install any far superior 5" speaker.
I’m able to produce both front and rear mounts on demand at a cost of £435 (Including postage if you’re within the UK). The mounts are 3D printed at 100% infill, not hollow or honeycomb.
The amp mount can also be produced upon request for £180, (formed from a single sheet of 5mm aluminium, plasma cut & folded into the perfect shape to mount in place of the cars original sub). All holes are pre-drilled and it’s made to take any Audison Forza amp. A 70mm Stainless-steel blanking plate (to cover the bottom free-to-air sub drain-hole).
Speaker wiring colour codes will also be included, saving you hours of time.
I’ve personally completed this upgrade to my own Emira and the difference is night and day – If you enjoy your music as much as the car, then this upgrade is definitely worth it!
I’m sure there will be many questions, and hopefully I’ll have all of the answers as the installation was completed by myself (plus taken 100’s of pictures along the way should these also be of interest).
Thanks a lot! It's really impressive that you did this on your own.
I'm also very interested in implementing this, but unfortunately I'm blessed with two left hands and little patience.
Did you need any special tools (apart from the 3d printer)?
Did you insulate any other areas apart from the doors?
Many thanks in advance!
