Car shows "limp mode" or "reduced acceleration" warnings (possible ECU issue)
So based on experience today with miltek valve in “mode 1” it definitely causes limp mode and MIL light. Happened repeatedly while pushing hard. Took it out at lunch time and been fine all afternoon. Will be writing to miltek and requesting a refund as its either faulty or doesnt work
I experienced the reduced acceleration warning and ESC error on a drive on the weekend after driving 1,000 miles. No rain, no wash - car was totally dry. I have 3rd cat delete. It randomly turned on as I was driving slowly through a neighbourhood. Parked locked the car, went for lunch. When I returned, error message gone - drove home 7hour drive - no error again. I assume its something flaky. I guess I’ll wait if it comes up again.
April 24 build car, I've had it since June and zero issues outside of some paint defects. Well unfortunately today I'm joining the "Engine reduced acceleration" club. No error codes or check engine lights, just a pop up warning followed by the redline reduction. It was 95 degrees in Chicago today and I was in terrible traffic for well over an hour (AC cranking of course), hopefully just a case of things getting too hot?
I'll keep people posted if this was a one time deal or if it continues to pop up.
Could any of this or anyone in the thread comment on if this is an alternator issue?
Reason I asked this question is because my alternator went out and my car died while driving. Look at my original post from before from 2-3 weeks ago.
The summary is we were fitted with 150 amp alternator, as in warmer weather in US, need higher Amp, so the cars require 180 A in the US. That is how I understand it from Lotus.
I got this the other day after driving about 3 miles. It unexpectedly went back to normal before shutting the car off.
Just got my car - have only driven it 200 miles. Was driving it in sport mode today (yeah, I know the break in period recommendations but haven’t gone over 4k rpm a lot….), and same thing happened to me. Parked, turned ignition off and then on and it disappeared. Will see if it happens again. Sorry (but relieved) that others are in the same boat.
Happened to me in the 800 mile range during normal driving - shut car down, waited 3 min, restarted, hasn't come back in over 100 miles so far.
Mine at 2200 miles... car went into same limp/reduced power mode again.... 5th time....today was a cool 65F wx... so my previous 3 posts of this happening in hot wx (100F) at spirited driving only , is now out the window.... fock....
Wtf... what is the solution to this ?, I will try to read the code.... CEL is ON even though it went back to normal operation after restart....
Also, still having issues of car not starting, until I F with the alarm on,off few times..... annoying
Definitely can't get away fast if Jason or Freddie chasing me .... fml
I feel like the ESC Service Required error is something different. I had it happen to me once about 300 miles ago. Like others, it went away after a restart.
I’m on my 3rd Mass Airflow Sensor…same issue each time.
Did the same route where I got this error. LA to LA Quinta and back again on the same day.
No issues. No limp mode. Similar ambient temps. It was a similar driving style, but maybe less aggressive
Do you have an OBD-II reader, and if so, can you plug it in? Since the same thing happened (no CEL) but a limp mode, I am curious if we have the same reported error code.
I apologize for digging up the past here. I found your post, which is precisely what happened to me, and I read through it and realized you and I are asking the same question, "WTF happened?" and I haven't seen an answer anywhere yet.
I have had mine for a week now, has 2k miles on it and today driving in stop/go traffic and got the reduced acceleration error….
I am in NJ so temps are pretty cold…. Turned it off to come in for my overnight work, will check in the am if it goes away. Will also stop at the dealer on my way home tomorrow, the car has zero mods.
Took it in today, once I get info back will post it here. The limp home mode went away after I restarted the car, but the check engine light remained.
I haven't see this since that first incident.
I haven't been using the Miltech (as some have reported here it could be related) and it's been in whatever the default position is.
When I did go in for break-in service Lotus Galpin claims the computer didn't show anything.
If you have a CEL @Jt-40 then I'll be curious to see what your ODD-II reader / or service center has to say about it.
I will ask them what that is reader says when I get my call back
