Emira Exhaust Upgrade?
No it’s stuck open if it was stuck closed I’m sure I would have gotten that error.
I saw the little spring and motor it’s attached. When I used the remote and look at it. I can hear it move and see it trying to move. It move very little but like it’s suppose to.
So that’s my question if my issues is an update or is it something else. Wonder if anyone else had this issue and fixed it with a recalibration at the dealership
could be bad servo or fuse to the circuit is going bad.
i have heard from my service center that they have been replacing the whole exhaust unit (muffler assembly) due to reduced accel error... so could be that too. the valve might just be stuck, and would need to be replaced as a whole.
if its stuck and they cant reach in there to free it and keep it free its probably going to be 4-6 weeks for a new exhaust.
So there is no way to replace the value motor only. It has to be the entire system which is like 3600k. I have the Milltek exhaust so I would have to swap back to oem to take it in.
That’s a pain in the ass. Does anyone know of a aftermarket value motor or a way I can get just the motor?
Has anyone had any experience with an emissions inspection (USA) and/or any sort of warning lights or warranty concerns while having the cat delete pipe? Really want to do this but don't want to have to uninstall/reinstall it for an emissions test or have warranty rejections or complications with it being on.
Have you checked fuse #15 in the front fuse junction box? There have been instances where the Milltek VC module shorts out internally, blowing that fuse.
If you do indeed have a blown fuse, your Milltek VC has shorted out.
