Question about auto shift knob
MapleOreo
46
39
Can someone, especially those with a shop manual, tell me how the shifter knob comes off?
Is it threaded and twists off? Does it have a set screw that holds it on?
I appreciate any help that you guys can provide. Thanks.
I believe there is a set screw on the back "facing the dash". Loosen the set screw and unscrew.
If I'm wrong someone will correct me
The knob is threaded on, so it "unscrews" but you first have to remove a set screw. Here's a thread which may help you doing the re-install:
The thread you referenced talks about the knob on the standard transmission.
I'm looking for info about the knob on the auto transmission.
You are correct. I just read the post incorrectly. sorry for the misinformation. I need to pay better attention. I saw "shop manual" and my brain went to manual transmission
My bad as well: I see the title of your thread mentions AUTO SHIFT KNOB. This proves we Forum members who've been around for a bit and so focused on the manual transmission, will have to "shift gears" (pun intended) and realize we'll be seeing more and more postings from those enjoying the Emira automatic transmission, moreso with the i4 model now. I'll look at my shop manual when I'm home to see if I can be more helpful (sorry again).
It's all good.
That's why I put auto in the title.
Cause I new you die hard manual guys would jump in to help when you read "shift knob" lol.
It took me awhile to locate, but page 17-11 of my Emira “service manual” mentions removal of the “lever handle - gear selector”. See attached photo of that page. That’s all I found for you.
