Blackthought_
Thanks. have the Goodyear F1s, but it probably doesn’t make a lot of difference. Next time I think I’ll lower them a couple of more lbs and see what that feels like.I run 26f and 28r hot on the Cups on track.
Any more than that and you will eat tyres quickly.
Yes, had the same thing on both the original F1 and the Cup 2 I fitted (not LTS version). Hot pressures could jump a lot. I don’t remember exactly, but the rise was significant. First session with F1 and the pressures jumped at least 8psi.Just returned from a track day at Summit Point and have some comments and observations. For background I have raced formula cars and sports racing cars for many years and am very familiar with the track. In the first session I went out with the stock tire pressures 29 front, 32 rear. After the session the tires were 35 front and 40 rear. I was shocked, but I don’t really have experience with driving a car this heavy….formula car would increase 2-3 psi. The rear of the car moved around a lt under breaking. Dropped the pressures to 32-34 hot and the car was generally much better but still squirrelly in the rear. Has anyone else had a pressure increase of this magnitude?
With the rear moving around so much my first thought is there is too much rear brake bias. Not adjustable as far as I know. Anyone else have this issue? In general the car is pretty neutral and turns in well. I have the touring suspension and different shocks and some shock tuning could substantially increase the handling qualities on the track.
I will, but need to bed everything back in properly this time. The brakes were a mess before skimming the front discs, but touch wood, I think we’re gonna be good now after the skim.Let us know how you like the Endless pads and fluid. I have a friend who swears by both.
This is a great tip!Here is an old autocross trick to find your track tire pressures:
There are small triangles around the outside edge of the tread that point to the wear bars. They are also conveniently located at the seam between the tread and sidewall. Rub some chalk along the shoulder of each tire in several places, so you can see the fresh wear. Adjust the pressures so that the wear is just at the top of the triangles. This is near optimum for performance and then you can make small adjustments from there for balance and feel.
Were the original discs worn out, or you swapped out for the improved performance? Any noticeable improvement in braking versus OEM?Alcon discs and bells up front. Now to build a rear bell.
