Emira Exhaust Upgrade?
Maybe I'm missing something... there is a lot of mention of the Militek. But all it gets you is a remote control for the valve?
Which...you can already control with Tour/Sport/Track mode? What exactly is having the remote supposed to help with?
Value control for Emira is unlike many manufacturers, where usually the value partly open or fully open depending on the driving mode, it is controlled by engine speed and other elements which means you can be on track mode and. still value open no more than 30%. Miltek's controller takes care of that
Please keep us updated if the value stay intact if you do track. We have many incidents value got melted down from Ti exhausts.
I certainly will! I have an Autocross event on Saturday and a full track day at COTA on Sunday.
Can you expand on this? Are you saying the metal flap itself melts, or the electronic valve actuator? And is this specific to Ti exhaust?
It allows you full control of the valves. You can rode around with the valves 100% open all the time. Current setup even in sport the valves only open at 4k but with the controller it’ll be open even below that
The value actuator and the harness, which leads to engine light and possibly locking power. So far it is only related to Ti exhaust as its temperature is so much hotter than the SS exhaust
Ahhh, I see. Makes sense it's the electronics and plastics. They even built in a little air scoop to help cool the actuator... lol. I wonder if there shouldn't be some type of a heat brake insulation mod to help prevent heat conductance, and also additional shielding to protect it from radiating heat.
Just curious, why would the Ti exhaust be so much hotter than SS?
