does a car come with the manual?Okay I read the whole manual, where’s my car?
If there's one spot on the car that needs PPF, it's this. I'm going to cringe every time a friend with fingernails opens the passenger door
I thought you'd bought an expensive manual that took around 2 years to mainly copy and paste from their previous ones, interns have to do something......
Ive known both porsche and bmw replace DC wheels under normal warranty past 12mths. To me they're admitting they're poor quality.That's fairly typical for DC wheels, as the finish is more fragile. When my Evora wheels were refurbished 2-3 years ago they would only warrant them for 12 months. I don't think the original handbook/warranty made specific mention of them, but that was 11 years ago.
You need the surrounding area as well -- that's the most scratched up part -- the area right on top of the handle itself. Especially if someone wears rings.
Did you guys notice the car has a downforce gauge? I guess it’s just modeled off of speed?
No launch control on the manual ? that being said I never used it once on my Exige !Some useful bits I noticed are below. I also read that it has an AGM battery, so that's interesting.
I can use that for a radar detector, tooNifty feature…
Pulling Fuse 22 in the boot means the Vantage exhaust is full bore all the time - sounds epic.No information in the technical data section on the suspension geometry settings. Shame - I would be interested to see the difference between touring and sport, and between sport with Cup2s or Goodyears.
On a similarly geeky note, I see there is a fuse for the exhaust actuator. Wonder if pulling this out would leave the exhaust flap permanently open (does the trick on an Aston Vantage apparently) ?![]()
Porsche has this on their GT3 manual. You push in the clutch and mash the gas pedal and the car holds it at 5k. You are then supposed to dump the clutch and launch it. Nice way to abuse your trans hahaHow works a launch control on manual ?
