~el~jefe~
- Jan 6, 2022
- 267
- 187
a 718 S Porsche with 350 hp, 309 torque, is past the limit of adhesion if you stomp the gas on a well paved road. 400hp and lower gearing, which this Emira has, you will be a road vegetable. the car is less than 3200 lbs, most like 3100 and change. The car weighs too little to use that full pedal on a twisting road, nor even probably 1/2 pressed pedal. Straight line cars need downforce or all-wheel drive. 3600-3800 lbs car adds a huge amount of downforce for acceleration. Grip is everything at 300+ torque 300+ hp. a 500 hp version of this would behave no better than a 400 hp version. it is under 3200 lbs. That 100 above 300 hp would only be useful for 60 mph to 150 mph pulls to fight drag.
