📓 Journals kitkat's Emira
I think this works if you are going for more of a racecar vibe- alcantara interior or race bucket seats. For a more GT or luxury feel I think stock looks better. But yea either way amazing mod. 👏👏👏
And what about on top of gear install a Ferrari lever looks, made on metal
  • #104
This could be achieved by prototyping a gated plate and then having cnc cut.
You’d then need to unbolt the adjustable lockout plate so that the shifter can freely shift into reverse without lifting the collar.
Now comes the tricky part, you would need to remove the lockout sleeve from the shifter and hope the remaining shaft is thin enough so that you can fabricate an actual H pattern plate without any overlap.
  • #105
You can see that you’d have to remove, 6, 12, 2, 23, 24, 31 and thread the knob directly to shaft 3. Then you pray that part 3 is thin enough at the plane where you plan to put the plate to be able to make a non overlapping 6 speed with reverse plate H pattern.
