Blackthought_
If you are going from 140 into a hairpin turn that is going to be hard on your brakes lap after lap. Kind of a judgement call and depends on how aggressively you drive. If you’re asking the question I have to assume that you’ll likely be on the less aggressive side and are probably still ok. you’ll just get squishy pedals and may decide to retire earlier than running all day. What’s the track? Maybe others with specific experience can chime in.What is co s
What is considered high speed track? I think the most I’ve hit on my GT was 145 down to 30 or 40
Ah, gotcha. NJMP - the thunderbolt trackIf you are going from 140 into a hairpin turn that is going to be hard on your brakes lap after lap. Kind of a judgement call and depends on how aggressively you drive. If you’re asking the question I have to assume that you’ll likely be on the less aggressive side and are probably still ok. you’ll just get squishy pedals and may decide to retire earlier than running all day. What’s the track? Maybe others with specific experience can chime in.
I tracked mine (sport with F1, 2.0 AMG). I trashed the brake pads in 20 mins. Still had brakes, but nearly new pads looked a bit of a mess and lost 50% or more on the front pads (not a high speed track, max speed circa 100mph), but I was breaking like I was in a track car.Who else has tracked their Emira on a stock setup? Debating on whether one should change ‘almost new’ brake fluid.
I’ve done 4 track days this season with the Emira on a stock setup. No issues with brake fluid. It all depends on the track - for the Emira, I have only had time to take it to Blackhawk Farms (a short, technical track).Who else has tracked their Emira on a stock setup? Debating on whether one should change ‘almost new’ brake fluid.
Agreed, the stock brakes aren’t bad. Just go a bit easy on them and they are fine. Even when I was pushing them harder than I should, they still worked and never let me down. For the next 25 minute session I braked gentler and they worked fine and are still working fine.@Blackthought_ The stock fluid will be fine, have ran a few sessions in middle east summer and it held up without a problem. The pads as others have mentioned will wear quickly. I say get out there with it stock and have some fun!
Nice. You used stock fluid too? No brake fade?Agreed, the stock brakes aren’t bad. Just go a bit easy on them and they are fine. Even when I was pushing them harder than I should, they still worked and never let me down. For the next 25 minute session I braked gentler and they worked fine and are still working fine.
Actually the rears are fine and are not worn down much at all. It’s the fronts that took the beating and kind of started to fall apart in small chunks. I’m swapping them out this week and will take some pics and post them up.
Recently I’ve been driving in dedicated track cars to do my race license. Those cars had brakes you could abuse all day with not a grumble.
Yes, totally standard brakes and fluid. Sport suspension, with Goodyear F1. Tyres were pretty good and brakes weren’t bad at all. If I’d gone a bit gentler on the brakes, they would be totally fine. They were still stopping me but you could tell they weren’t happy.Nice. You used stock fluid too? No brake fade?
